Vmax540
Just curious, You know the little disk like filter under the oil tank do you change it yearly ? If you're careful about not getting debris in the tank while filling why bother ? Maybe if you change from petrol based to synthetics or change brands it would be time for a change ? I've had alot of sleds over the years and never saw one plug up.... maybe I'm just lucky ?
Yamahammer485
I wouldnt change it.
Like you said, your most likely not going to be getting any debris in the oil resevoir, so the filter should last a very long time, and it doesnt see the same use as a fuel filter would, as the sled uses and goes through several more tanks of gas before the oil resevoir is empty.
Never had a problem with the filters in our two strokes, including our 86' Bravo which ran on conventional style Yamalube for many many years, then went to Amsoil no problem.
PowerValve-700
Just pull the oil line off and see how well the oil flows. I've never seen one plug up myself.
maxdlx
VIP Lifetime Member
I thought that was only a check valve, never knew it was a filter. Maxdlx
