M mayquad New member Joined Aug 16, 2006 Messages 3 Aug 16, 2006 #1 I have a 1200XL ltd. The sponson tore off the side, bolts and all. I drilled thru the outer hull and welded hex head bolts to the metal plate and re fiberglassed. It lasted about a week and tore off again. Any help
TimeBomb New member Joined Jan 2, 2005 Messages 679 Age 43 Location Waddington, N.Y. Aug 16, 2006 #2 hmmm, tough one. try looking on rivaforums.com, alot of guys on there that know alot about waverunners. its a forum like ty but just for pwcs.
redsnake3 New member Joined Feb 3, 2005 Messages 1,171 Age 41 Location labrador home of snow Aug 16, 2006 #3 only thing i could think it would be would be if they were not adjusted the same and one was taking too much pressure.
M mayquad New member Joined Aug 16, 2006 Messages 3 Aug 17, 2006 #4 thanks red & TB I'll check the placement and see what's up at riva.
ajviper New member Joined Mar 10, 2004 Messages 603 Age 49 Location Michigan Aug 18, 2006 #5 The best forum on the web for personal watercraft is www.pwctoday.com Go under the Yamaha section and post your question. You definitely need to reinforce the hull before remounting.
