Upnorthguy00
Got a 1991 Waverunner III. I was rideing it a few weekes ago and burnt the rear piston. The Cylinder didnt look bad so I hoaned out both sides and put pistons, Rings, Wrist pins and Cages in it. Also replaced all the gaskets. The Motor starts and runs good. I checked the compression and found the rear Cylinder at 110 psi and the Front at 130 psi. Both side hold there pressures. My question is, Will this be a problem? Will it blow up again because of this? or dose it not make much difference.
