Pipe for the Phazer II.
I had a 1992 Phazer 2 , I put a PSI Torque pipe on it, never touched the jetting, put a 1 inch track on it, did some clutching on it, and it was a blast, 1 pull and go every time, then i jumped up to a 1993 Exciter 2 sx, I still remember how much fun that sled was, it was a ROCKET that year, keep the carbs dialed in and the clutches clean, you can run thoes sleds to the pin all day, GOOD TIMES CHEERS
I had CB Performance work on both my 02 SRX last year and I had then do a Phazer II rebuild after I had a catastrophic rocker arm seizure and blew a hoel the size of a beer can through the top and bottom end. They ported the motor and put the Aaen pipe on it; jetted it and man-the thing flies!!!! I am thinking about having them do a roller secondary on it and throw a new track on there too.
