aaen srx pipes
I only ran the Power Inc's for two days, and I noticed a gain in the bottom end and midrange. I tried them out on my big bore, and found that they didnt' flow enough for the bigger cylinders. I have them setup now on a stock 700 motor, but I only did that at the end of the year, so i'm not sure how they will work. I ran bender's big bore pipes for a bit. They don't work on a stock motor. They work on a ported motor, but the gains are very minimal, and they're certainly not worth the money, if you can find a set. Even the gains with those pipes on a big bore isn't anything to write home about. If you want pipes that work on an SRX, buy high RPM pipes. They're the only ones that work well, but who wants to spin a trail sled at 10K rpm. The stock pipes are the best to keep. If you want to save weight, put a Bender can on yours, and take off the heat shields, and get your stock pipes ceramic coated.
