seanmurphy26
newb question but what is the difference between hyvo and non hyvo gears? how can you tell the difference. thanks.
hyvo are stronger, longer lasting and more efficient. you can tell the gears by the lower part of the gear is wider and tooth is straighter cut. the chain links have a curve cut in them that you can see from the side. they absolutely wont interchange with each other.
seanmurphy26
thank you for the info. so what does my 98 700 sx have?
ovalracer
non hyvo
ovalracer said:non hyvo
non hyvo and 15 wide chain and gears for 98-99 SRX
seanmurphy26
thanks guys
