Carb?
2datrl
NE IL.
This past spring when I pulled the carb bowl plugs on my viper they had a black/brown sludge on all three of the plugs. Should I a. pull all three bowls, clean and inspect, b. pull the carbs completely. c run sea foam in the gas. or d. try to have it done ubder warranty by the dealer.
Thanks 2datrl
Pull them and clean them. The dealer will never clean the carbs under warranty. Then run seafoam in every 3rd tank full. Maxdlx
I was afraid of that.
Thanks, as always you have been very helpful.
2datrl
