chain case question
seanmurphy26
milo maine
well i took the chin case apart to change the track. (done this before). when i went to put it together i confused my self on what goes where. there are 3 spacers, smaller one, and 2 bigger ones (one with a rubber oring inside it) what goes where? i had it all as i took it apart but now 3 weeks later i confused myself. any help would be great
98 700 sx
the spacers with the o ring are for the upper and lower shaft for the seals to run on. they go on the back side of the chain case. it is best to install these in the seals before installing the chaincase. if you do it in reverse you can damage the seal easier.
the other two spacers are for behind the gears.
there is only one spacer with the o ring in it...id think this wold go on the bottom shaft (no room on the top for behind the case). thanks i think i can figure it out now. hopefully
