2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
As many of you have read, we are in the process of developing a belt drive system for SRX/Viper chassis up to the Apex Chassis. The pricing is not final yet; However, we are guessing the entire system would be in the $1600-$1800 range. For some if not most this is a lot of coin to fork over on an older sled so I was wondering how many people would be interested in this setup for their sled? The benefits to this system go as follows:
Drive Axel = 5.25 pounds weight savings
Jack Shaft = 2 pounds weight savings
Entire belt system housing = 1-2 pounds weight savings
gears and belt = 2 pounds weight savings
Drilled rotor = .56 pounds weight savings (changing to viper rotor or later model SRX rotor puts you at a pound)
Total weight savings = 11-12 pounds, 10 pounds of which are rotating.
As you can clearly see, the majority of the of this weight loss is due from rotating weight which is HUGE. The other benefit to this system is obviously looks and you do not have a chain being dragged through oil. There is less total friction in transfering the power to the track.
I am throwing this question out there to see if there is any interest in this system. We expect to have the system tested and ready near christmas. If you have any questions about the system, please let me know and I will be happy to answer them for you. Post right here what you think about the pricing and if you would consider the system or not. Prototype pictures below. Thanks
-Matt
-Matt
