SNOWRULES
I have a 2000 SXR 700 with PSI tripples, reed spacers, one layer removed from the head gasket, and a heel clicker kit in the primary. Just wondering what helix and spring combo I should use in the secondary? There's a 54/44 maxx perf. helix on ebay for cheap would this work well? Thanks
The 54/44 is wayyyyyyyytoo steep for heelclickers with psi pipes in that sled. If you want to use hc,s u need a shallow helix. I have a 45/41 or a 45/39; both of which will work with those weights in your sled with psi pipes. $60 shipped for either helix. 54/44 ain,t even close to what you need!!!!!
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
I believe x2ryder is selling that helix from this site and as Turk stated, that helix is way to much to pull for that sled, and in somecases even to much for an SRX.
SNOWRULES
turk wich of those helixes would be better? the sled already rips corner to corner and i do alot of lake running would one of those give me a better topend on the lake than the other?
The 45/39 would be a little better because it would allow you to run a little more tip weight & pull better top end.
SNOWRULES
turk do you have paypal if so please pm me with your info so i can send you a payment for that helix. otherwise just let me know the best way to make a payment. thanks Jonathan
