What helix should I use?
SNOWRULES
Ottawa. Ontario, Canada
I have a 2000 SXR 700 with PSI tripples, reed spacers, one layer removed from the head gasket, and a heel clicker kit in the primary. Just wondering what helix and spring combo I should use in the secondary? There's a 54/44 maxx perf. helix on ebay for cheap would this work well? Thanks
The 54/44 is wayyyyyyyytoo steep for heelclickers with psi pipes in that sled. If you want to use hc,s u need a shallow helix. I have a 45/41 or a 45/39; both of which will work with those weights in your sled with psi pipes. $60 shipped for either helix. 54/44 ain,t even close to what you need!!!!!
turk wich of those helixes would be better? the sled already rips corner to corner and i do alot of lake running would one of those give me a better topend on the lake than the other?
The 45/39 would be a little better because it would allow you to run a little more tip weight & pull better top end.
turk do you have paypal if so please pm me with your info so i can send you a payment for that helix. otherwise just let me know the best way to make a payment. thanks Jonathan
