yamaman700
I need to install a cigarette lighter type of outlet. My MM doesn't have electric start or a battery so I don't know how to connect it. Anyone have any ideas??
You can run it off a lighting circuit. I double check the wiring diagram on that model tonight. (gotta go eat right now)
What do you plan to run off it?
yamaman700
I'm looking to run my GPS. Not much else.
A good source is the blue wire under your handle bar pad...it's the brake hot load side...steady source and is fused...splice into it and find a good ground, your good to go...the only drawback to this application is if you blow your fuse you don't have a stop lite...I wire all my heatshields this way...it may not be the best, but I never blew a fuse yet...mike
Yes the blue wire that comes out of the load control relay (the one with the white plug) is regulated voltage. On the MM, I do not think it is fused. However, the MM should have condensers before the load control relay (red wire), so the power should be fairly smooth.
yamaman700
Thanks guys that's great help.
