Gone Blue
SS,
The light just came on! I was thinking there was a special "T" connector that I did not have. I just realized what you were talking about!
Three wires from the fuse box go to one side of the sled lighting connector and the other two wires go to the other side of the sled connector.
Thanks again, I owe you one. G.B.
SneekySnake
Life Member
Ok here it is . On your main harness right where your 3 sided plug is for the
starter relay there is a 3 wire plug together . it has a dark blue , a light blue,and
a red wire . These come down from the top .
The other side of that plug will have a blue & white ,a blue & grey ,and
a red & yellow . Unplug this and the plugs and wires from the fuse block will match right up . Hope this helps . If not I took some pic. of it and can try to send them
to you .
SS
to you .
SS
Gone Blue
SS,
I think I got. I am going to finish twisting wires together and try it out. Thanks again for you help. G.B.
SneekySnake
Life Member
Any time GB . You will find it is worth the time when it is realy cold out and you watch all your buds yarning on the rewind . Reverse is worth it too . Have fun .
SS
SS
I'm sorry that I didnt get back with you.. I still have racecar on the brain!!!! i put an electric start and revrse kit on my viper and I also have a VIPER ER and I've never looked to see if they were different systems.. i am glad you got it figured out!!! Gary Oles nosboy
Gone Blue
Gary,
No problem, thanks for your help. When I turn the key the starter works. I still need to get some Loctite so I can install the starter ring and hear the engine run. Other than that, I am there.
Brett
Brett
