you can do nothing if your racing it, the tps is only for part throttle settings, adjust timing slightly to enhance gas mpg and throttle response and has no outcome what so ever on a motor for wide open hp output, tested it on a dyno, once with tps connected but in idle spot, once with tps maxxed out and once with it removed entirely from the harness, all the same outcomes, no differance.
