gmcsrx
Just wondering what to do with the TPS when fitting 38 mm carbs.Thanks
yamaholic22
PSI makes a kit for mounting a TPS to other carbs if your cdi required a TPS input to function properly, such as the srxs and vipers.
you can do nothing if your racing it, the tps is only for part throttle settings, adjust timing slightly to enhance gas mpg and throttle response and has no outcome what so ever on a motor for wide open hp output, tested it on a dyno, once with tps connected but in idle spot, once with tps maxxed out and once with it removed entirely from the harness, all the same outcomes, no differance.
gmcsrx
Thanks guys
