hereismylife
97 600 twin carb question (stock sled) tring to finish this up tonight
I am tring to get the carbs finished tonight on the sled.
The sled is stock. I was reading that these machines run rich from factory.
I did some searching on here to about this matter.
MY QUESTION IS
Can I lower the needle to lean her out so I can get some better gas milage.
Also I might be doing the head gasket mod ( maybe )
I have 3 positions to pick from
acording to the book 4 is at the top 2 in the middle ( stock ) 5 is at the bottom
Also I have 2 plastic washers that are under the clip. ( stock )
This sled will be used in pa and ny area.
any help would be great
MY QUESTION IS
Dave_Vmax600
uh i dont think you would want to lean out your sled if your running higher compression(head gasket mod)
BOOM!
BOOM!
yamyrider
leave the jetting stock to be safe in colder weather with the head gasket mod...
hereismylife
Ok here is what I did for now.
I put the clip in the 1 position at the top of the needle with both washers underneath the clip. I wonder how she will run in the snow...
