136" Extension - Suspension Setup ?
xsivhp
Eau Claire, WI
I'm converting a 1998 XTC 700 from 121 to 136" - what have people been using for suspension set-ups in the skid?
Thanks,
xs
I just reset mine from the begining. Get it in, set the limiters to where the track is flat. Then lift the rear of the sled so the track is off the ground, get the center spring so there is zero preload on it, then turn it 3 full turns. Set the fra in the middle before starting all of this. Once the center is set, lower the sled and use the rear spring to set your 50/50 gap. Maxdlx
