anyone got problem of top speed with a predator 1.0to1.1/4 track it seem heavy to run
tunme
- Mar 2, 2005
yup!i had an ice claw and lost 10 mph on top end,replaced it with a hacksaw
1'' and all is back to normal,also the hacksaw gives a much better bite .
ok i maybe sell that track predator .....thnx for the advise
do u have the model of your hacksaw 1 inches
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
Kinda confused here, the ice claw performs very well when it comes to top speed runs, just as well as the hacksaw top speed wise. Make sure to test the tracks in equal conditions. As for the Predator losing topspeed, it will perform equally to the hacksaw in top speed runs. The predator is a great all around track and highly recommended from everyone.
sxviper32
i vote for the ripsaw...haha, had to say it matt!
well something not going good for me cause i got no more top speed with that predator 1.0to 1.1/4 track so ill think ill switch that track for some other things.. do u know what is a good weight for a track on srx 700
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
Lets put it this way, the lightest fully clipped track that camoplast offers weighs in at 33 pounds (.54 lug racing track) and the 1" predator clipped everythird weighs in at 34 pounds.
quebec#1
I dont understand ? do you have a 1 inch predator or a 1.1/4 inch track ? Of course a one inch track will be a little faster than a 1.1/4 inch track.modsrx said:well something not going good for me cause i got no more top speed with that predator 1.0to 1.1/4 track so ill think ill switch that track for some other things.. do u know what is a good weight for a track on srx 700
what about 1 1/4 predator weight
mmm
they sell me the track and they told me it was a 1 inches to 1 1/4 inch track does they have parts number on those track ill go check if they have
quebec#1
I think they sold you a 1 1/4 inch track , and that could explain the loss in speed , also it might be rubbing a litlle in the tunnel.modsrx said:they sell me the track and they told me it was a 1 inches to 1 1/4 inch track does they have parts number on those track ill go check if they have
mmm
i see it last year on camoplast site but i can't find it no more it was really haft 1 inch and haft 1 1/4 weird
ExpertXViper
The 9818 which is the 1.25in Predator clipped every third window weighs 35 pounds. Have the box sitting in my room and it says right on it.
the hump or higher on the side and lower in middle
i have some photo if someone can help me about my track
yamyrider
is it a fingure track or cone track as some call it.
ExpertXViper
Your trying to figure out if you have a 1in or 1.25 Predator track right????? If so just measure the lug weight. Models numbers, 1in is 9830 clipped every third and the 1.25 is 9818 clipped every third. If its a 1.25in track its prolly rubbering on the heat exchangers protectors and will rubber on your tunnel protectors also when the suspension does its thing. I removed the tunnel and front heat exchanger protectors on my Viper so it wont rub, but I'm not running studs either.
yamyrider
the fingure preditor is a 9892. The number should be on the track.
