I bought the hauck brackets and have them installed, but just not sure how it's supposed to work- if I leave the sway bar attached, I have to compress the shock as much or more than the stock SRX shock...so I removed the sway bar link and it lines up much better. Question is, has anyone done this (is it the right way) and can I mount the sway bar directly to the swing arm like that? Am I doing this correctly?
loosen the bolts under your transfer rods and it will be easy..
sorry, that was a little vague...I should have clarified more- I'm working on the front suspension shocks now.
maxdlx
VIP Lifetime Member
without long travel front rad rods, you do preload the LT shocks, and really end up with short travel long travel shocks Maxdlx
