I bought the hauck brackets and have them installed, but just not sure how it's supposed to work- if I leave the sway bar attached, I have to compress the shock as much or more than the stock SRX shock...so I removed the sway bar link and it lines up much better. Question is, has anyone done this (is it the right way) and can I mount the sway bar directly to the swing arm like that? Am I doing this correctly?
loosen the bolts under your transfer rods and it will be easy..
sorry, that was a little vague...I should have clarified more- I'm working on the front suspension shocks now.
without long travel front rad rods, you do preload the LT shocks, and really end up with short travel long travel shocks Maxdlx
