Fuel line routing
tarditim
Alberta
Ive got a bravo 250 for the kid the engine was out of it so I put it in now the only problem I have is the fuel and oil injection lines. Not sure as to the routing does anyone have or know where I could source this out?
greatly appreciated
Marc
What year, twin or single...fuel tank or oil tank...carb(s)??? What I do is go to T.Y. website and the left hand side-scroll down to the bottom and click on ONLINE PARTS and your in...no need to register just go to parts cat. Then just follow the prompts and select application, year, and model...then choose what you want to look at and go from there...I use this method to cross reference parts that I'm buying and to see if I'm getting what I was sent...Hope this helps
I am looking for the fuel tank to carb, oil tank to injector and so forth it is a single 250 1984. Ill check the links thanks
that would is a good tool, but unfortunately it wont help with the routing? Anyone else know where the lines may go?
