studs
blue missile
bucksport maine
i want to stud my old yammi track with the studs out of my srx. and was wondering where to get the tool to punch holes in the track and a studding pattern, i'm not even sure the length of the track. but if you want to see something that hooks up cra**y my old xlv is the one to see.
Its not quite a punch that makes the holes for the studs, its more of a drill bit type, but innstead of cutting teeth, the leading edge is round but heats up due to friction from spiining, and preety much melts its way through the rubber, but it is also sharp, and it is hollow to allow the peice of rubber to evacuate the bit.
Also, just a tip, studs, if barely used can be re-used, but you need new locknuts and removing the old studs can be a real pain in the butt.
Here is a pic of the bit, its at the bottom of the page.
http://www.royaldistributing.com/servlet/MiddleRedirect?page=274.html&cat=winter
