I looked at a '79 SRX with 8J000 stamped (not factory) in the heads. Any significance to this?
SRXfromHELL
Pitcrew
Yamaha shows 8JO head for 78,79,and 80 srx440
YAMMIEGOD3:16
YA, LOTS OF SIGNIFICANCE!!!! THAT 1979 SRX HAS CORRECT HEADS ON IT, WHERE YA GET NOT FACTORY FROM !!! THOSE ARE CORRECT HEADS. THOSE HEADS WERE USED ON 79/80 SRX. 8G9 HEADS WERE USED ON 78 SRX. MATTER OF FACT MODEL PREFIX FOR 1979 SRX IS 8J0. DUDE, CHECK NUMBERS ON YOUR HEADS, NOT REALLY A BIG DEAL. 3:16 (tony)
my 79 was also stamped in top of heads with punch dies, it was bought new like that.
Also, offended?? not hardly. I offered you a rear secondary with stock helix, extra optional helix, and a new spring for $50 if you dont want it no big deal. there was only 2 helix available for that secondary, the one they came with and the optional one. I doubt you can even buy them anymore, but you could check at your dealer, I could be wrong. willing to guess the helix and spring will be more then $50. Good Luck with your project.
Yep, like you said mrviper700, it's punched, but very crudely! My secondary is fine shape, but I'll take the spring and helix. Has it got a steeper angle for strictly grass dragging, and do you want to sell the other items you mentioned? (manual, clutching,gearing,jetting specs and pics)
...Mike
...Mike
