Folks,
I need to replace the rt. trailing arm and radius rods on my '01 SRX-700. Was thinking of upgrading to an SXR type with longer travel. Looks like all the part #s are different (i.e. shocks, t-arms, radius rods,) yet shock and radius rod bracket angles are the same. It looks to me like a bolt on swap if I find a wrecked SXR.
If I have to buy everything in pieces, can I use my KYB shock housings and just buy longer shafts?
Am I right in thinking this is an easy swap and if anyone has done this, what were your results?
Thanks in advance.
Thanks in advance.
RIVERRUNNER
Search this forum, you will find a ton of information all about what you are asking!!!!!
