Removing rivet from clutch weight?
norwegian
Well-known member
norway
How do you remove a rivet from a clutch weight without damaging the weight? I "know that you use a center punch and drill in the middle"? But, still, how do you remove the core without grinding????
or just grind the head off and pound the body of it through with a center punch, either way works
That's what I'm trying to avoid, grinding. I have a tendency to clutter it up completly.
