Which clutch do I have?
dnale
South Lyon, Michigan
I have a 96 600xt. I don't know for sure which clutch it has. I'll post photos tomorrow. I don't think it's stock because I think that the previous owner had mentioned something about putting on a 95 model clutch instead of rebuilding it. I rebuilt it once, but since I have everything out and want it all right, I might as well look into the clutch. Should I have the YXR?
I will check mine. I put a 96 600 XT secondary on my 94 Vmax 600 ST and need to take some pics of it anyway. I will post some pics of everything.
ok, here are the pic's. It's dirty. I haven't gotten to it yet. The only numbers I found were some on the back of it. I think it says 8AC (maybe 8AB, can't remember.)
That is the number that will tell you which clutch it is....8AB, 8AC...etc. Clean it so you can read that entire #. It is definately a YXR type though.
Steve (O.C.)
I'm not looking for clutching. I've already got it set up. I just wanted to make sure I was getting the correct bushings, etc. I've even recommended that you start with those setting in a PM.
La de da to that answer!
:homework:
