I'm looking for info on how excactly the TORS and TPS sensors function together on my 04 ViperS. Does this sled have an ECM? Its not fuel injected , so why does it need a TPS sensor?
mrviper700 said:the tps is connected to the cdi box, what it does is change the cruising speed timing to throttle sensative input, this gains you improved response from the engine and fuel economy.
the tors switch is just a safety device so in case the throttle would stick the sled wont keep going wide open after you release the flipper.
