snow3
I have a bender red and yellow secondary spring with a bender helix for my 2002 viper, with trippple pipes. What numbers in the secondary should I have my spring in? I have it in 3-6 now.
that seam like a lot of twist...what do you want it to do??? back shift more or have more top end.
snow3
I would more top end, you have any suggestions?
loosen the twist will give you more top end and worse back shift.....tighter will take away top end and make it back shift faster to some extent....
MountainMax
Red/yellow bender spring, hmm, They told me to run this spring at 0,3 and it's mainly used for deep snow, better backshifting......
if you are at 0 and 3 then that is a off set spring....
