Secondary
snow3
Central Pa
I have a bender red and yellow secondary spring with a bender helix for my 2002 viper, with trippple pipes. What numbers in the secondary should I have my spring in? I have it in 3-6 now.
loosen the twist will give you more top end and worse back shift.....tighter will take away top end and make it back shift faster to some extent....
takes two men to get that spring @ 3-6 ( 90 deg. ). that is way too much twist. set @ 20 or 30 deg. either setting will give great backshift. will not affect top speed.
