Need a 12 volt power input
Venom
Holyrood, Newfoundland, Canada
Hi,
Looking for a 12 volt power input (like a car cigarette lighter) so I can plug my GPS into. I had one last year, but it died within a month (it was water resistant). I need something alittle better I guess.
Cheers.
12 volt
Under the handle bar pad there is a blue wire, this wire is the hot feed to the brake light switch. It is a good source and steady power. But if your sled is equipped with a battery. Then go directly to the battery...good luck...Hint do a search on the topic you wish info on and you will be surprise to see all the responses to the question you want answered…
