G Geezer New member Joined Mar 31, 2004 Messages 6 Location NW Ohio Nov 13, 2006 #1 Where should the top of the belt ride in the primary at full shift? Thanks yamaholic22 Active member Joined Oct 23, 2003 Messages 5,275 Location Iowa Nov 14, 2006 #2 on stock yamaha clutches (no machining done) the belt will ride about 3/8" away from the top of the primary sheaves at "full" shift out. You must log in or register to reply here.
