If I run it on the 4th clip it has a low-midrange burble. I suppose I could try some 42 needles, but I'm already 2 turns out on the pilots. As far as the needle jet, it is fixed, so I can't do to much about that. I have looked into different needles, but I need a chart that lists the diameters to determine if it is going to be to lean or rich.
I do not have an airbox, just uni filters, so the carbs are vented to the bellypan. I may try putting the airbox back in there to see what happens, but first I need to really spend some time and get the carbs synched in better. I just did them with a drill bit, but I am going to try it with a manometer.
