2002 viper
- Aug 7, 2006
So you think that real black plug is fouled and thats why gas is going threw the pipe?
ViperTom
2002 viper said:So you think that real black plug is fouled and thats why gas is going threw the pipe?
Yup!!!!!
2002 viper
- Aug 7, 2006
Makes sense, Ill get plugs today and we will see. Thanks for your help..Hope this works!
B2SO
- Aug 18, 2003
check your oil pump cable near the carbs , the cable has Joint there , my gueass would be that the cable is not in its boot all the way and your oil pump is wide open . just follow the cable from the bars and you will see where the cable has what looks like a rubbler boot on it . the cable splits there . make sure that is all put back together , because if you pulled the air box out , i would bet that cable is not set all the way in the boot and the pump is open to far ......that would explain the excess oil .. just a thought ...good look
Viper-Rules!
Probabily carb floats!
You probaily need your carb floats adjusted. I had mine stick before on previous sleds and everytime you start it, it will throw about a cup or two of raw gas out the end of the pipe and onto the floor.
2002 viper
- Aug 7, 2006
Thats what it does, Makes a pretty big puddle on the ground!Viper-Rules! said:You probaily need your carb floats adjusted. I had mine stick before on previous sleds and everytime you start it, it will throw about a cup or two of raw guys out the end of the pipe and onto the floor.
2002 viper
- Aug 7, 2006
Well I changed the plugs and put some new gas in it and its still doing the same thing, We ran it on the grass and it still has its power didnt lose any of it...You guys think because its so warm out its running rich?? When we ran it there was smoke coming off the grass where the oil landed.
B2SO
- Aug 18, 2003
did ya check the pump cable ??? also when a oil pump fails it fails wide open so you dont burn them up ...
2002 viper
- Aug 7, 2006
No, It has seemed to stop after running it around the grass for awhile...But The plugs are like a brownish color...dont this mean its running to hot?? Which could very well be because im running it on grass.B2SO said:did ya check the pump cable ??? also when a oil pump fails it fails wide open so you dont burn them up ...
B2SO
- Aug 18, 2003
A Hot Plug Will Be A Grey Or White Color , You Want A Light Brown (cardboard) Look To Them , But Thats When You Get To Riding Temps ... Just By The Amount Of Smoke Your Talking , I Would Check The Cable ..
2002 viper
- Aug 7, 2006
Where is it exactly?? And how would I know if its open?
