Tough ???
Jerkiness, hum. hum. Well I'm taking a stab here, I would say its just ring drag air transfer giving some resistance but across several pistons and at different intervals. I have my engine as we speak on the bench and I just rotated it, no plugs exhaust W or reeds on sort of does it to…How was your compression…If in doubt pull your W exhaust manifold off and take a good look inside. As you rotate the crank you will know if there is something going on…If nothing looks funny than check end play on the crank, there should be no movement…still in doubt, pull carb rack off then reeds out and take a look inside…If compression was good and their might be a crank issue or bearing failure. Pieces of bearings have a way of making it’s way up into the exhaust can, remove and shake out over a white bed sheet and see what comes out…I know not much help…Good luck.
