No, Lyle, what I am saying is where you posted that benders pipes only make 132hp and that they lied about being 153hp "busted", thats where it originated from.
Sure, you can show a gain or loss and know if a "part" is doing something on that paticular day and under those conditions, and I beleive the silencer information you posted was valid and exactly what you found on "that day" but to state that the pipes dont make the power I will tell you is incorrect unless you can match the dyno conditions exactly. Ask your buddy running the dyno since he has worked on a superflow before what would be the outcome with 85% air density and 100+% percent???? Are you dynoing in a temp controlled enviorment and have access to change the relative humidity and the air density??
So if you put a stock viper on the dyno and it doesnt read 122hp was yamaha lieing about it???
I think the best thing here would be that you call Jim at dynotech and ask him if you can get the same numbers with a dynomite as you can a superflow, no need to talk with me I dont know anything, Jim does it for a living, has a superflow 901 and does all the dyno work for the snowmobile shootouts and then give Gus Bohne a call, he worked for dynomite for years and years and ask him as to the differances between the 2, you might get a bit of differnt information then your used to hearing, and it will be the SAME thing from 2 completely differnt guys.
Can you post the dyno sheet for this?? so we can see the bsfc, air density, water temp etc. would like to see the chart, not the graph.
