rivet locations in clutches - help!!
According to the fiche, its the other way around. #25(rivet-17.2mm) inside and #26 (rivet-13.9mm) outside. Anybody know for sure?
There was some discussion about this when the Viper first came out. My 02 came from the factory with 13.9 inner 17.2 outer. Which is also what the factory service manual says.
The 8EK weight force really tapers off on the high end. So Viper's tend to over-rev on the top end. Installing the lighter rivit in the outer hole usually makes the top end over-rev worse, ( with 8EK weights and stock secondary clutching).
