x2ryder
I just found a pink secondary spring that came in a used secodary that I bought last year. Is this spring good for anything racing etc??
yamaholic22
that is a STIFF spring
x2ryder
I am trying decide if this spring is pink or red that is just faded? It does not seem as stiff as my silver spring.
vipertripplexxx
Pink has less compression force than the silver, but way, way more twist rate. Very hard to twist. Some guys run them with a very high helixes.
If the coils are thinner it is a faded red spring. if the coils are thicker it is a RX-1/Apex pink secondary spring.
x2ryder
I think it is a faded red.
change_up
It probably is a faded red. I had the same idea last season when I started to do some clutching. I only found out that it was a red spring after taking the warrior clutch apart and seeing the difference. Kinda hard to tell if the spring has been used a significant amount.
