need help with my 94 vmax 600 dx
jones5s
Quebec, Canada
alright my primairy clutch has been making some abnormal sounds almost like a rubbing it just isnt normal, it seems like my spring is loose or just worn down. i was wondering for any information on how to cheak this to find out what the problem is.
secondly my chaincase sometimes makes almost a grinding noise when im coming to a stop i changed my gear oil and it was really thick and black but no metal chunks so i need to know how to cheak for this problem aswell and also how much oil to put back in.
my problems with the sled arn't very detailed but any comments and ideas are more then apreciated thank you.
also i am new to totallyamaha so hows everyone doing?
:2strokes:
Pull the chaincase cover off and have a look inside. The bolt that secures the bottom gear to the axle might be backing out and rubbing on the case. That happened to a friend of mine last year. The bolt finaly came all the way out, gear came off spline, broke chain, broke case cover. Not good. Find where the noise is coming from, or you will end up broke down on the trail - that is no fun.
Oil fill is 8.5 US ounces
The secondary clutch can make a strange noise when you come to a stop. As for the primary would pull cover and check spider bushing and weights for binding.
