roller secondary
gates26
ontario
If I run a 45 deg straight helix, should I run a straight 40 in a roller secondary? Just wondering if when running a roller secondary you should generaly lower the angle or increase the angle.
It depends whose the manufacterer of the roller is. Some rollers u gotta add 10 degrees & some are the same. All of em are different.
It is a hauck roller, The secondary clutch sheave has to be machined to install it and it can run a stock style helix.
