Mark / C&C PowerSports
Just wondering if anyone has done this to a 2000 SXR style sled. I would like to see what they look like, and what you changed for gearing and clutching. This sled will be used on the trails as well as off the trails. Thanks
EricMichael
well most ext kits come with tunnel extention,rail ext. hose's and covers and new cross over tube.On models with rear exchangers you will need to remove it and use the cross over tube. maybe go with 8cr weights, 21/40 gearing.go here and its a few pics of your style sled with the 136 http://www.totallyamaha.net/forums/showthread.php?t=27423&highlight=136+ext
Yammerhead
Here are some pics from when I went 136 on my 97 700SX. Used a stock tunnel extension and a 2" track. I am still playing with gearing but I went to 8 tooth drivers for track clearance so it is quite a bit different than the stock ratio.
Stretched 97 700SX
Stretched 97 700SX
The Webmaster (Tom) has one that is really sweet. At least he still had it the last I knew.
Should be pics in the photo section.
See Tom's sled here . . .
http://www.totallyamaha.com/Mr_Sled/index.html
skid
i was also wondering if a stock yamaha 136" skid could be bolted in place without any major mods...
