Its either going to be this one,
206094A 94C CLUTCH - 30MM 1:10 tapered bore. Adjust to belts 1-3/16" thru 1-1/2" wide. Comes with kit #205828A pre-installed. Stock #206094A thus accepts both 1-3/16" and 1-1/4" wide belts, just as it comes - right out of the box. Also contains six pucks #205918A and orange spring #205583A. Since the majority of snowmobiles, including those with engines such as Kohler, CCW (Kiritz), JLO, Hirth, Tohatsu, Kawasaki, Sachs Kiehaefer, Mercury, Xenoah, Suzuki, Yamaha, etc. have a 30MM - or occasionally a 25MM 1:10 tapered crank, this is the most popular DUSTER clutch. Also for FL 350 Odyssey.
OR
212629A 94C CLUTCH - 30MM 1:10 tapered bore. For 1-1/4" wide belts - contains 6 pucks #205918A and red spring #212631A. Limited application. This clutch is ONLY for those Yamaha models built from about 1974 to the present, which require a gear attached to the back side of the clutch for driving oil injection system. Included among the models, most Exciters, etc. This COMET clutch DOES NOT interchange with nor fit all Yamaha "geared" models. If there is any question of it, check with your Yamaha dealer.
You will have to ask your dealer on which one it's going to be but it will be one of those two.
