Thats a drawback,, but,, i've talked to a few people about that theory of having more compression with the carbon on top of the piston... NATURALLY, here are MY findings...( you KNEW IT didn't you???).. a TWO STROKE MOTOR rely's on Crankcase scavenging theory to remove the burned hydrocarbons and SPENT FUEL... The carbon, just like a NON PORTED and POLISHED motor, slows down the exhaust gasses that are trying to leave the motor... The porting and polishing both the intake tract and exhaust tract will help TREMENDOUSLY with the motors ability to "breathe".. My theory (and I MIGHT BE WRONG) is,, the more air/fuel you can SHOVE into a motor the better HORSEPOWER the motor will produce!!! providing it has a easy way OUT of the motor...Backpresssure in the exhaust ACTUALLY slows you down.. I understand we are talking trail sleds here and some backpressure is necessary to keep the cylinder temps from melting pistons,,,but,,,in theory,, EXHAUST PIPES SLOW YOU DOWN!!! If you look at FUEL MOTORS at the NHRA events.. the dragsters use the SMALLEST LENGTH of PIPES they can get away with!!! (also the BIGGEST BORES TOO) The compression that you gain does not do ANYTHING to the performance of the engine unless you have a way to figure out the ADDED OCTANE and the difference in the jetting to compensate... So,, in closing,, I do NOT BELIEVE the "old wise tale" that a dirty combustion chamber actually HELPS you any!!! Yes, the compression is higher,,,but the detrimental effect of airflow has ALSO been hindered... WHADDAYA THINK????? Gary Oles nosboy
