yamaracer18
this year i put in a dalton black primary spring i cant really tell if it is better then my orange maxx perf spring i was running last year, do u guys have any ideas of what kinda performance i should expect form this new spring and do u think it is better then teh orange one form last year?
Primary spring is a small part of the clutching equation. Are you happy with engagement rpm,s & are you turning proper rpm,s at wide open throttle.
yamaracer18
i am engaging at around 4200 not sure of the peak rpms yet havent had snow to try but the primary will not rreally cause any loss in performance? is this correct i am running a green secondary and a 48/40 helix i think it is with 80 degrees of twist simons cpr pipes with the cpr modded head and vforce 3 reeds weights i can rmemeber how heavy they are ran really good last year with the orange spring in teh primary just experimenting now with some diff clutch techniques to get a little more outa the hole and in the mid
