steering slop
BLUEBALLER
Manitoba
2000 sxr with about an inch of play in the bars. I've removed the airbox and pipes to get a better look, and I can see the steering column move back and forth quite a bit underneath the reed cages. I've looked at the microfiche and can see that there are two sets of nylon flanges that hold the steering column somewhat true. I can see the top flange mounts to the frame, does anyone know what the bottom flange mounts to? It looks like i'm gonna have to pull the motor to fix it properly. If anyone knows how much play there should be down there, let me know as it looks like it's moving way to much for my liking. All the play is before the idler arm, so it's not the ski's or the idler arm.
the bottom flange mounts to the front heat exchanger. i took the two nylon flanges and remover a little material from the mating surfaces of each so they squeeze on the steering column a little more. worked great for me.
