srx plug gapping
92vwgti
quebec, canada
so i need to know i run br9 ecs in my srx 700.. when i buy these plugs are they pre-gapped or do i need to do it myself? ifso what are the measurments? well thanks for any info
with the above said, make sure to get the correct ones. ngk makes several of these plugs none of which are to be regapped. they are solid top, and screw top, .5mm (tight gap) and .8mm (srx and doo sdi gap). so at least 4 different in total. check them with a gapper before you make the 8.00 mistake and leave the dealer with the wrong plugs. if the dealer tells you they only make one ecs plug, i would be changing dealers. the electrode is ground different and the weld is smaller. re-gapping may cause fatigue and the electrode to fall into the motor.
