Vmax Al
I am assuming that the curl and lifting of the reed petal is a bad thing since it will allow air in when it shouldn't. Would this lead to bogging at take-off? I will be replacing all but do any of these show the correct position?
Is it correct that they should lay flat and I would see the black line/surface contact all around the edge?
Thanks,
Al
Thanks,
Al
Al you are correct. That set of reeds looks junk to me. Maxdlx
Yes - tired pedals and cracked stoppers - Just get OEM pedals and stoppers. Use locktight on the small screws holding the stoppers.
Tod
Tod
Also agree,junk, get new OEM...
yes they should lay flat.
Vmax Al
Thanks for the feedback, parts are to arrive tomorrow for install this weekend!
marcush
- Dec 24, 2003
I have inslalled new reeds that had minimual lifting and had no problems.We have to remember here guys those reeds slam shut on the down stroke
