the track on my sled is almost due for a change, what is the maximum lug height I could go to, currently running stock, and not do any major mods to the tunnel, etc.
I run a 1.25 ripsaw on my sled with no issues. BTW, I bought the track from a friend who used it on his 97 600 SX, reason he changed it was he extended his rail to make it a long track.
If you are running (stock) 9 tooth drivers and have no tunnel or heat exchanger protectors you can go with a max height of 1.5".
If you want to run studs you can go with a lug height of 1" with 9 tooth drivers.
If you go to a 1.25" and want to run studs you will have to go to an 8 tooth driver and change your gears to get the proper ratio.
