HELLO GUYS I BOUGHT AN 02 VIPER USED AND WANTED TO CHECK THE CHAIN ANY SPECS OR TENSION TIPS THANKS...... ALSO I ASKED ABOUT OIL CHOICES AND IM GOING TO RUN AMSOIL INTERCEPTER THE SLED HAS A HALF A TANK OF MAXIUM TUNDRA R ANY SUGGESTIONS ON HOW TO MAKE THE SWITCH SHOULD I DRAIN IT ???????????????
Concept Carbon
Ok adjust chain so it has about 3/8play on each side of the long section. replace your gearoil with a good quality atfafter you do this check to make sure there is no leaks.
for the oil i would run it till its almost empty and fill it up with amsoil, i dont think there would be any probs with mixxing the 2.
if you use the search you will find many posts on atf oil and chain tension.
