woolyviper
what is a bored silencer, and how do you bore one?
xt700
- Jan 27, 2006
theres two different versions
when looking into the outlet of the stock exaust youl see a bafle plate
1- drill one 1 1/2 inch hole in the plate
or drill 5 1/2 inch holes in the plate
dont know wich is best mine is 5 holes love the sound and from what i can tell there is a performance gain.
Pat
Pat
yamaholic22
As XT said it is cutting some out of the final baffle of the exhaust, allows it to breath easier, sounds better, and adds a little bit of horsepower. That along with the reed stopper notch and taking a layer or two out of the headgasket is good for a few horses.
Do you have to make any jetting changes if you drill the holes? How loud does it make your exhaust, is it a deeper sound?
EricMichael
I thought this mod. could only be done to the sx style motors?
yes non powervalve sx motor's 600 and 700 tripple
yamaholic22
No you dont have to rejet, the stock jetting is fat enough as it is to allowing flowing some more air safely.
So I can't do this to my srx?
yamaholic22
Nope can't do it on the srx. A couple years ago someone took an srx stock canister apart and gutted it out, and i believe they did the same thing with a viper silencer as well, and then put them on the dyno to see if there were any gains and they found no benefit in gutting those particular silencers, only the non-powervalve 6 and 700's.
woolyviper
I wonder how they sounded. I'm just looking for a little extra sound.yamaholic22 said:Nope can't do it on the srx. A couple years ago someone took an srx stock canister apart and gutted it out, and i believe they did the same thing with a viper silencer as well, and then put them on the dyno to see if there were any gains and they found no benefit in gutting those particular silencers, only the non-powervalve 6 and 700's.
SWEDE
Go on the technical page, there is a sound clip there under silencer mod heading on one of those pages.
