allblkviper
I have some aaen pipes on there way and i'm looking for a way to get all that power to the track
EricMichael
Heel clickers 40-10 or 8dn-20 weights with larger rollers, stiffer primary spring.
allblkviper
any idea on cost?EricMichael said:Heel clickers 40-10 or 8dn-20 weights with larger rollers, stiffer primary spring.
EricMichael
not sure on the HC but the 8dn'20's and larger rollers from the dealer are about 140 without d/c. You can buy them on here used for about $85 for weights/rollers then you'll have to set up your secondary to match the primary for clutch efficiency.
